D17 ms carb probs
tim[in]
06-29-2007 15:46:20
My 17 runs fine while it is cold but when it starts getting hot after about 45 minutes it starts sputtering and i have to run it with choke all the way out.it has the MS carb. i rebuit carb and new float about a year ago.
Eldon (WA)
06-29-2007 20:27:07
 Re: D17 ms carb probs in reply to tim[in], 06-29-2007 15:46:20
Recheck the setting of the main jet also....I had a 170 that gave me fits for 2 years until I found that the seat for the jet was vibrating in and out, constantly changing the setting. I believe it should be 1 5/8 turns out.
tim[in]
06-29-2007 16:03:26
Thanks! i'll check this and a few other things when i get to farm this weekend.
old
06-29-2007 15:56:51
This may sound funny but check your spark when it starts doing that. You may find you have weak spark and if you have weak spark choking it makes it run richer and will burn the fuel better. Also you may have a clogged tank vent either one will cause that type of problem
