Tight piston rings question.
Tom Cumming
06-28-2007 20:17:45
I just put an engine rebuild kit in my Allis, "B" tractor, and the pistons are _really_ tight because of the rings.
I just replaced everything (sleves, pistons, rings, bearings everywhere, newly ground crank, etc.).
The rings are sprung out so much that the pistons are really hard to move once I get them in. I checked the distance between the ends of the ring once it's inside the sleve, and it seems to be fine.
To give you an idea how tight, once I have the pistons connected to the crank, I have to take a large screw driver as a lever to get the crank to turn. Even then it's not easy. I certainly can't turn the crank by hand.
I haven't done this before, so maybe I just had unreal expectations. But it's a lot stiffer than I expected. I don't see how the starter can turn this thing over.
Anybody got any ideas?
Thanx, tom
dardan
07-02-2007 10:36:21
 Re: Tight piston rings question. in reply to Tom Cumming, 06-28-2007 20:17:45
If you cannot turn it over with the hand crank, something is not right. Without the the rods hooked up, the crank should spin easy, and slide back and forth easy.
I always do 1 cyl, then turn crank several turns to get feel, and to seat things in a little. Then do next cyl and turn, and so on.
I use 50 weight engine oil to dip the ringed pistons in before installing, (heavy enough to stay and lube, thin enough to not drag excessivly). Also washes off gasket surfaces easily with a little thinner. Also use 50 wt for rest of engine assembly. Use moly to lube cam lobes and lifter faces. Had good results on many engines for self and others.
Engine will smoke real nasty on start up, but will settle down after a couple of minutes.
Hate to see a tow start because an engine is tight, too many damaged parts that way. Rods rolled around crank, ect.
steve(ill)
06-29-2007 15:45:36
run in to this all the time. i finally started to check the torque required to roll the motor. makae sure the rings have oil on them, and the bore, and all bearings. put a bolt in the end of the crank and use a torque wrench to move it. takes 24 pounds to roll when at TDC and about 40 ft pounds to keep it moving when all 4 are in center stroke. im with you, that seems likea lot of drag, but those rings do most of it, and its normal.
Tom Cumming
06-29-2007 15:53:24
 Re: Tight piston rings question. in reply to steve(ill), 06-29-2007 15:45:36
Ya, I'd guess (didn't try it) that that's about how much (40 ft lbs) it would take to turn it.
I think I was worrying about noth'n.
Thanx!
tom.c
Butch(OH)
06-29-2007 04:39:18
A new motor will be stiff but should not be tight. Of course those terms are relative to my my arm stregnth. None the less if it cannot be turned over with the hand crank you have a problem (or two) Are you certain that the drag is in the rings and not the rod bearings? Here is how you find out. Turn the crank so you have two pistons at the top and two at the bottom. If ring drag is the problem the engine should turn freely for a few degrees either way from TDC (top dead center) beacuse the pistons are hardly moving. Since you have checked end gaps and if you determanin that the drag is in the rings then most likely you have the oil rings improperly installed. It is easy to lap the ends of the expander instead of butting them and it will drag hard. If they are lapped they are also likey messed up and will require replacement. If the crank turns hard even with the pistons at TDC and BDC then you have bearing drag. This could be from not having enough clearance on the crank or from having the rods improperly installed causing a side bind.
Tom Cumming
06-29-2007 14:47:31
 Re: Tight piston rings question. in reply to Butch(OH), 06-29-2007 04:39:18
I think the real problem is that I had the expectation that it would have been easier to turn over.
I'm certain the bearings are ok, b/c it seemed to me that the piston was tight in the sleeve even before I attached it to the crank. I was also pretty careful and plastigaged it and did end up having to put some shims in.
Per your suggestion, I will double check the oil rings (I partly pulled it apart anyway). I doubt that I could have screwed up all four of them.
Before I posted my question I did a search of the forums, and found a mix of answers ranging from, "it should turn easy", to more than one person who had to do things like tow their his Allis to get it to turn over the first time. I suspect that's what I'll end up doing.
Thanx again, tom.c
David Maddux
06-29-2007 03:30:12
I am in the process of rebuilding a C right now. The end gap on rings should be between .007 and .17. It will be stiff and when you get it all put together you should not be able to turn it over without a bar or something. If you have the pistons in it and you can turn the crank by hand, something is way too loose.
davpal
06-28-2007 21:51:45
How did the crank turn over when you put in the new bearings. It may be too tight. If it is the rings did you check the end gaps with a feeler gauge? It should measure about .004 thousands for each inch of cylinder bore. So a 3 inch bore would have right around .012 end gap. Little more wouldn't hurt. New engines do turn over pretty hard when you are assembling them. Very unlikely you would be able to spin it over by hand anyway.
old
06-28-2007 20:46:48
Well first off did you check ring gap in the cylinders before you put them on the pistons?? If you didn't then you could have a problem. Also did you use a good prelube on all parts when you assembled the engine?? If you didn't then thats is also a problem. Did you make sure you had oil or something on your fingers before handleing the new parts?? If not then that also could be a problem because the acid in you finger tips can/will cause problems. Learned that when I took an engine apart and found finger prints on the rod and main bearing from the person who rebuilt an engine. My self I use STP oil treatment on my engines on all parts and my hands when rebuilding an engine
