D17 Series III coil
CliffordPaul
06-28-2007 15:18:50
OK. I assume I fried my coil, so I went to my local Agco guy, tell him I want a new coil for said machine, and I get one with a resister tacked on the side of it. I told him my old one didn't have one on - in fact, I took the old coil in when I ordered the new one because I'm not well versed in these things - but he said it's what's presently called for and will work. Should I put this thing on or am I getting bad info?
Thanks
CliffordPaul
06-29-2007 14:10:37
 Re: D17 Series III coil in reply to CliffordPaul, 06-28-2007 15:18:50
So - there are no other changes I have to make in the system now that I've added the resister - I'm to assume it works with the same points, condenser as my old coil without the ballast?
El Toro
06-28-2007 16:30:22
Is this a 12 volt system that was originally 6 volts? On these tractors that's been converted to 12 volts usually have a ballast resistor installed in the wire from the ignition switch to the coil. If you have a resistor installed in the wire to the coil now you need to remove it.
Just hook the wire from your ignition switch to the + terminal on the new coil if your battery is negative grounded. Hal
CliffordPaull
06-29-2007 08:06:19
 Re: D17 Series III coil in reply to El Toro, 06-28-2007 16:30:22
From what I'm gathering, the D17's generally came through as 12 volt; mine is postive ground and it all looks pretty original. But to add to the confusion, the ITT manual I have seems to indicate a resister in the wiring diagram of the Series IV but not the series III. What's with that? Thanks CP
El Toro
06-29-2007 09:08:01
 Re: D17 Series III coil in reply to CliffordPaull, 06-29-2007 08:06:19
They use those ballast resistors to drop the voltage so the points will last longer. You will
need to connect the wire from your ignition switch
to the _ minus terminal on the coil. Since the new coil has a builtin resistor you should run a new wire from your ignition switch to the coil. Napa sells those 12 volt coils with a builtin resistor too. Hal
