wc runs hot
wckid
06-28-2007 09:35:54
hay guys i have a 36 wc unstyled and it runs hot this is a non presurized system and it spits water out of the over flow and cap when run for more than 10 min or so . it crank starts easy 1 or 2 cranks and runs very good before i got it, it had a new head put on it. what do you think?????
wckid
07-02-2007 07:24:34
 Re: wc runs hot in reply to wckid, 06-28-2007 09:35:54
garry you might be on to some thing . will check that. it was home made by the old guy that put the tractor together. old just where would a fella find the thermostat on a 1936 wc????
Garry from SD
07-01-2007 09:32:31
My dad's WC ran on the warm side til we discovered the exhaust pipe was pushed too far into the manifold.
bjb in Ne
06-28-2007 13:54:01
Is it possible the radiator overflow tube is plugged? It might just be overfilled and spitting out the excess. There also may be a vacuum lock. Do you have straight water in it that get drained out frequently? It takes a bit for all the air to work its way out of the system.
old
06-28-2007 11:21:21
First place to start is the thermostat and change/check it. If its good next thing to do is a complete cooling system flush. The way I do a flush is with vinagar. Drain the system fill with vinagar and run it till good and warm, let it cool some then drain it and back flush it with a garden hose. Rig up an hose adaptor that will hook into the block drain and let the water flow for a couple of hours
