WD45 Clutch
John B
06-27-2007 22:06:55
What is the best way to change the CLutch on the WD45? DO you have to split the tractor or dose`t it come out from under the battery box?
old
06-28-2007 08:32:39
 Re: WD45 Clutch in reply to John B, 06-27-2007 22:06:55
Wel if your talking about the engine clutch you have to pull the engine. On a WD45 you don't split the tractor like you would on a ford but you just pull the engine out from between the frame rails
Are you sure?
06-27-2007 22:26:38
Which one are you working on, the slip clutch(hand clutch) or the dry clutch?
John B
06-28-2007 08:32:19
 Re: WD45 Clutch in reply to Are you sure?, 06-27-2007 22:26:38
When I take off in 4th gear it seems like the clutch is slipping. The hand clutch is in all the way. The other gears seem to be fine when takeing off. Also the tractor wants to JUMP out of 4th gear while going down the road. Any idea what might be causing that? Thanks.
