AC C final drive
Don Peterson
10-11-1999 06:36:38
Does anyone know how to drain the gear oil out of the final drive of an Allis Chalmers C tractor.
Brian G.
10-11-1999 07:11:29
 Re: AC C final drive in reply to Don Peterson, 10-11-1999 06:36:38
Unfortunately, the only way is to remove the pans. Not really a big deal, though. I just made an interesting discovery about the recommended lube. This info is from original A-C Operating Instruction Manuals. The "B" & "CA" both call for 20W at all times. The "C" calls for: Above 32 degrees: SAE 140, Below 32 degrees: SAE 90. Figure that one out! Capacity is 1-1/2 pints. For comparison, the WD & WD-45 both call for 80EP. I use modern 80/90 gear oil in both my WD & WD-45.
DONALD GENESSE
09-09-2000 08:35:59
 Re: Re: AC C final drive in reply to Brian G., 10-11-1999 07:11:29
hi check for final drive for cat 330 no 7y0768 or timco 445 17858 .tanks
