WD 45 Rocker question
Roddo
06-26-2007 18:33:11
I recently overhauled a seized engine in my grandfathers WD 45. Someone else tore it apart and I got it as a basket case. The manual is not very clear on how to assemble the rockers. Does the rocker shaft bolt down and then the oil baffle bolt on to that or do they all go on together? I test fit it with the oil baffle under the nuts that hold down the rocker shaft and it seemed to hit the rockers as it was too close. I then installed the rocker shaft and set the baffle on top of that but it looks like the valve cover may not be able to squish the gasket properly.
Anyone that can give me a clue?
mlpankey
06-27-2007 17:00:44
 Re: WD 45 Rocker question in reply to Roddo, 06-26-2007 18:33:11
bolts down by the same bolys that hold the valve cover.
