Wet sleeve o-ring lube?
David Maddux
06-25-2007 18:54:18
What do you guys use for the o-ring lube. I have a C to do and was thinking about vegetable oil?
El Toro
06-26-2007 06:27:25
 Re: Wet sleeve o-ring lube? in reply to David Maddux, 06-25-2007 18:54:18
I would use dish detergent. Hal
Butch(OH)
06-26-2007 05:28:46
I use lubriplate engine assembly lube.
boog
06-26-2007 05:03:47
I also used dish soap but had problems because I froze the sleeves and heated the block. The sleeves slid in real easy. But just before sliding them in, I put some soap on the sleeves and it froze also. I suppose if I had just put soap on the o-rings in the hot block I'd not have had this problem :)
old
06-25-2007 19:06:46
When your wifes not looking steal her dish soap. Best stuff you can use. I used Dawn dish soap when I did my C
