Hey TxAllisMan
Dick L
06-25-2007 13:38:03
On the D 15 oil pump. You sure can put the D15 oil pump in your C. The body is a little larger to accommodate the larger rotor but the mounting holes are the same as on your C, or a B,CA,RC. Same stand pipe as well. I only used it because I drilled the crankshaft from the mains to the rods and needed the extra volume.
TxAllisMan
06-25-2007 17:21:26
 Re: Hey TxAllisMan in reply to Dick L, 06-25-2007 13:38:03
Thanks for the reply Dick.
Im just about to get started with the second round of restoration of my c allis #552.
Thw first restore wasn"t that good due to it being our only tractor but now having the International 404 utility the C gets very little use and the darn starter ring gear is bad and I was going to replace the rear main seal while I had it split.
See I did an inframe on this tractor about 12 years ago and the rear main has always seeped a little oil.
I was going to replace the oil pump or rebuild it as I was considering replacing the camshaft bearings.
This tractor has had quite a workout since it was rebuilt over 12 years ago.
It does not burn any oil but I dont like the oil pressure after it gets hot.
I always use a wix or napa cotton packed oil filter with 10/40 oil.
I think the biggest part of my oil pressure drop after getting up to operating temp is due to the cam bearings because I didnt replace them when i did the inframe rebuild.
If I had it to do over I would have done a complete rebuild the first time.
Thanks for the info again Dick.
Damon
N.E. Texas
