WD hydraulic oil in rear end
persianorange_50
06-25-2007 10:54:17
My WD looses oil out of the hydraulic resevoir, and then it must be going into the rear end because oil will come out of the gear shifter when in road gear. Any ideas?
boog
06-26-2007 05:05:56
 Re: WD hydraulic oil in rear end in reply to persianorange_50, 06-25-2007 10:54:17
Yep, split tractor & replace seals. I just did this on a D14 and the 50 yr old seals were hard and cracked, leaking hyd fluid into the PD clutch.
JMS/MN
06-25-2007 11:07:43
Need to split the tractor and replace seals/gaskets between housings.
