WD 45 loader strength
Ron
10-10-1999 11:11:51
I have a WD 45 with power steering and and early model front end loader. It also has a scrape blade that can be attached instead of the loader bucket. I am thinking about adapting some hay forks to the loader to handle 4X5 bales of hay. I want to build some kind of hydraulic control mechanism to dump the bales. My question is: is the tractor big enough,is the hydraulics strong enough, and is the loader built strong enough to do this. I realize I would have to load the rear tires and maybe add some additional weight in the rear. Any experience with this or other thoughts about the feasibility of this would be helpful and appreciated. Thanks.
Ted Buisker
10-12-1999 05:23:28
 Re: WD 45 loader strength in reply to Ron, 10-10-1999 11:11:51
I used just such a loader on a WD to feed 6X6 Vermeer round bales to my dairy heifers for several years with no problems. I'd use the regular bucket, push as far under one side as I could, then wrap a chain from the loader frame around the top of the bale and back to the loader frame. this would keep the bale from tipping off the bucket. I had fluid in the rear tires, and one set of wheel weights. You will not be able to stack a bale that size (6X6), but you can scoot it around where you need it. The bales I had weighed approximately 1800 lbs, so smaller bales should be no problem. But keep the load low and BE CAREFUL!!! Ted
