D17 and large round bales
bgm
06-21-2007 14:42:17
Will A D17 handle 1500 lbs bales easily? I have found one and am thinking about replacimg my old WD with it. The WD will handle them. but not well.
D17JIM
06-23-2007 06:16:03
 Re: D17 and large round bales in reply to bgm, 06-21-2007 14:42:17
HEY JON T. I can"t beleive a JD man is bragging on a D-15 Allis. Finally wised up !!!!! LOL Jim
John T
06-22-2007 12:36:32
It sure will, I have a smaller D 15 with fluid in tires and extra wheel weights that will pick up a bale easyyyyy yyy on the rear 3 pt carrier plus its front loader with a spear will pick them up front also. HOWEVER I dont run over rough ground or ruts with a bale up front for fear the front suspension is a lil weak for that but theres nooooo o problem hauling big wet heavy bales on rear at all.
John T
Pair-a-dice farm
06-22-2007 12:08:17
My uncle used a D17 on a vermeer 605 baler that puts up a 5x6 bale, On bermuda grass it would probably be in excess of 1500# it handled them OK unless you were going uphill, it was best to back up.
old
06-21-2007 14:44:54
Should do just fine. Its heavier then the WD is and has about 20 more HP also. The D-17 is around a 52HP tractor and the WD is around 34HP.
