7080 hydraulic system
Hay Stack
06-19-2007 18:15:46
Just got this 7080 in. Very nice tractor. However the hydraulic system seems to loose prime or something like that. While running a swather it will run good then just disingage then run again. Same for the remotes. They will lift the swather a little then stop then lift a little more. The steering will work some times then next thing you know it takes off across the field. Its like it is low on fluid but it isnt.
Anyone have any ideas????? ? Your help would be appriciated.
thanksssss
Joe(TX)
06-19-2007 19:49:53
 Re: 7080 hydraulic system in reply to Hay Stack, 06-19-2007 18:15:46
Have you checked the filters and the fluid leval for the hydraulics. There are sight glasses on the left rear of the differential housing. The fill is behind the cab.
Hay Stack
06-19-2007 20:57:03
 Re: 7080 hydraulic system in reply to Joe(TX), 06-19-2007 19:49:53
Thanks for the reply..... .....
I did change the filter at the side of the engine, is there another? The fluid levels are good.
Joe(TX)
06-20-2007 04:14:30
 Re: 7080 hydraulic system in reply to Hay Stack, 06-19-2007 20:57:03
The two on the engine are for the engine.
There are 2 filters for the hydraulics in the differential housing. One on each side. There is also a transmission filter.
I would advise getting an owners manual from the dealer of somewhere online.
