WD 45 block
Mike from cny
06-18-2007 21:12:41
I have a WD 45 block thats cracked between the cylinders where the sleeves slide in. I've heard this is somewhat common and most people run it that way. Can any epoxy or sealer be used? What do you guys think?
Mike from cny
06-19-2007 20:08:03
 Re: WD 45 block in reply to Mike from cny, 06-18-2007 21:12:41
Yep thats them, I traded my running but rough WD for this WD45 thats in pieces. I'm trying to find out as much as I can before I start ordering parts. Thanks. -Mike
Texas Denny
06-19-2007 05:55:57
Robert is absolutely correct. Those cracks are not a issue.
Robert Mull
06-19-2007 05:36:10
If you are refering to a small crack between the cylinders on top , the head gasket will seal it. Most have these cracks.
