CA brake question
Steve in S. IL
06-18-2007 12:10:20
How do I know if I need to replace the brake bands on my CA?
I pulled the brake bands out of my CA. They are somewhat rusty. One hinge was actually stuck and I had to tap it to get it to come loose. I have run them through my electrolysis tank and they are much clean now.
Thanks,
Steve in S. IL
Steve in S. IL
06-18-2007 19:03:03
 Re: CA brake question in reply to Steve in S. IL, 06-18-2007 12:10:20
The bands are not worn too thin. I took the pads off the bands and ran them clean on the wire wheel. I'll but the pads and rivets.
How do you clean out the junk on the hand clutch side?
Steve in S. IL
JMS/MN
06-18-2007 16:33:31
When the bands are worn down to the rivets, time to replace. No rivets?- then how close is the band worn to the backup steel band>
Big Hunter
06-18-2007 12:19:36
does the bands have any lining on them? if there is no lining is the band worn thin? if the band isn't worn just free up the hinges and put new linings on them
