WC missing and quitting
MT in Walford
06-17-2007 18:26:41
I drove my WC home from the Homestead Iowa Tractor show today. It started missing and then would quit. Let it sit for 15 seconds and then it would start and go for a bit...then do it all over again. It seemed to able evenually to run and keep running if I didn't open the throttle too much. Do you think it is a fuel problem (float, gascalator, or fuel tank cap venting problem) or valve problem (gets warm and valves don't close) or a mag coil problem?
Thanks
Pastor Mike
Dick L
06-18-2007 13:23:43
 Re: WC missing and quitting in reply to MT in Walford, 06-17-2007 18:26:41
As aaron said, probly a fuel problem. Sounds like slow fuel flow. Just enough to keep it running at a slower rpm. If that is the cause it will be found between the carb and the fuel cap. Probly in the sediment bowl inlet. You will have to screw it out of the tank to check. Sure wouldn't hurt to take the fuel cap off first and give it a try. Fines can collect in the sediment bowl stem and you would wonder how any gas could get thru.
MT in Walford
06-28-2007 19:58:34
 Re: WC missing and quitting in reply to Dick L, 06-18-2007 13:23:43
I think we figured it out. The ground on the mag is bad. The ground on the side of the mag was shorting out. We disconnected the wire inside the mag to it...and it seems to be running fine. We could not get the coil out, the two screws are stuck, so we could get to the ground on the side of the mag. So we just disconnected it from the where the points and condenser wire connect together inside the mag.
We have to put it in fourth gear and apply the brakes and let out the clutch to kill the engine for the time being.
Dick L
06-18-2007 13:23:36
Dick L
06-18-2007 13:23:33
aaron b
06-17-2007 19:03:08
I think you're on the right track with your fuel system diagnosis. I would pull the fuel line off at the carb, turn on the gas, and verify if it flows freely. Could be a plugged screen in your sediment bowl. I bought some bad gas recently-it had reddish colored pulp in it, which plugged up the sediment bowls on two of my tractors. Good luck!
El Toro
06-17-2007 19:00:27
When the engine quits running you need to pull the coil wire from the cap and hold within 1/8-1/4" of good ground and have someone to make an attempt to start the tractor to see if the mag is still firing. Don't give the coil time to cool. Hal
MT in Walford
06-17-2007 20:04:52
 Re: WC missing and quitting in reply to El Toro, 06-17-2007 19:00:27
I misspoke. I meant to say condenser. I have a mag.
Pastor Mike
El Toro
06-18-2007 03:43:22
 Re: WC missing and quitting in reply to MT in Walford, 06-17-2007 20:04:52
You could change the condenser, but I think the coil could be the problem. Which mag is on the tractor? Hal
