ALLIS CHALMERS HD5G
Thomas Smith
06-16-2007 23:46:30
Need help on a HD5G with a 2-71 detroit motor. Motor will start up and run fine but when you go to put in in gear (under a load) the motor dies. What are some possible issues or things that need to be checked out. The throttle control and governs seem to be messed up..... ..... don't know any help would be greatly appreciated.
El Toro
06-17-2007 07:30:00
 Re: ALLIS CHALMERS HD5G in reply to Thomas Smith, 06-16-2007 23:46:30
You need to make sure you have clean fuel and new fuel filters. Then bleed the fuel system at the secondary fuel filter. That should be on the pressure side of the pump so it will purge out all the air. The Detroits are good about bleeding the air from the system. The military used lots of Detroit diesel engines. Hal
hector gemme
06-17-2007 03:08:09
Do you know if he smoke black that could be the air cleaner probleme or fuel filter or a bad injector.
