WD45 hyd.
Mark
10-09-1999 14:38:25
I just installed a 3 point on my 45. Kind of a home made operation but it looks good.
My problem is when I went to move a round bale it would not pick it up! I could feel it tring to lift but no go. Is there a relief valve or a pressure adjustment on the pump system ? Am I asking the tractor to do more then it can? Thanks for any ideas and info.
Chip
10-09-1999 19:17:09
 Re: WD45 hyd. in reply to Mark, 10-09-1999 14:38:25
I assume your hydraulics work to lift other things? Your hydraulic reservior is full? Pressure shouldn't be a problem as it has a 3000 psi system. Sounds like you may be getting air in your system. Borrow a high pressure gauge with a male pioneer tip on it. That would atleast tell you what your pressure is. That's one place to start. With snap coupler lift, our 45 will pick the front end right off the ground.
