model C misfires
Steve Howell
06-15-2007 06:02:39
Got this thing running. New mag. Only runs on cyl # 1 and 4 or 2 and 3 depending on which way I turn the mag drive. Why won"t it fire on all 4 cyl?? Thanks, Steve
El Toro
06-15-2007 13:40:55
 Re: model C misfires in reply to Steve Howell, 06-15-2007 06:02:39
If the wires aren't crossed you need to bring No1 piston to TDC on the compression stroke. Then pull the cap from the mag and see where the rotor is pointing. It should be at the No1 plug tower. Hal
Texas Denny
06-15-2007 07:30:39
I agree with Dick. Sounds like the wires are crossed. Sometimes you can get an engine to run with the wires in a random order. Firing order is 1243 with the number 1 cylinder in the front.
Steve Howell
06-16-2007 04:42:13
 Re: model C misfires in reply to Texas Denny, 06-15-2007 07:30:39
Yep, fireing order was wrong, thanks, Steve
Dick L
06-15-2007 07:25:15
Is your wires run as in the picture below???
third party image
Steve Howell
06-16-2007 04:39:37
 Re: model C misfires in reply to Dick L, 06-15-2007 07:25:15
Well, they do now and it runs great. I was told by the owner the fireing order was 1-4-3-2 but I see it is 1-2-4-3. Thanks, a picture is worth a thousand words, Steve
