WC TIMING HELP
LittleMackinawFarmall
06-14-2007 09:39:30
Admitting upfront I know NOTHING about WC's neighbor has a WC that had a hole in the block that was patched we found another WC motor and between the two managed to come up with one good motor.. the timing marks are where we are in total question as the marks arent the same from one came to the other...any suggestions or anyone he could call and visit with and maybe get some help on this sorry for the long post just would like to help a good neighbor out...
mawc
06-17-2007 17:55:09
 Re: WC TIMING HELP in reply to LittleMackinawFarmall, 06-14-2007 09:39:30
take the front cover off. the are 2 lines one on the gear of the cam and one on the gear on the crank. and far as the magneto there is no real way of lining it up. get the cam and the crank lined up it has to be perfect turn it over by hand and the lines on the crank and cam must meet. then put it all back together.take #1 plug out and put finger over hole turn engine over till you feel and puff coming out your finger then look down in with flaslight and bring piston all the way to top. looking at the cover on the magneto the bottom left is #1 take the cap off mag and turn the gear that goes in mesh with cam gear but be careful not to lose and governor components watch the rotor till it snaps and the metal strip is lined up where #1 wire is then putt all back together. Be very careful not to lose any governor components
gene (missouri)
06-15-2007 20:21:09
If you are talking about ignition timing. The marks are on the backside, along the edge, next to the pressure plate, of the flywheel. You need to remove the inspection place from the bottom of the bellhousing to view the timing marks.
Jerry Coulter
06-14-2007 11:08:56
The AC factory service manual says "Time the camshaft to the crankshaft by aligning the straight marks on each gear together."
John T
06-14-2007 10:18:30
You talking about crank to cam timing or ignition timign or what????? ? If the crank n cam are in time and ignition timing is the problem, get the No 1 cylinder to TDC on its Compresion Power Stroke and at that location the distributors (if timed correct on right tooth) rotor tip should be lined up with the cap tower leading to the No. 1 Cylinder and the ignition points just breaking open.
If more complicated then that dont ask me, IM NOT AN AC MAN but this generic timing advice ought to be okay.
John T
