WD-45 Not Running Well - Update
Phill Snartland
06-13-2007 06:43:32
Hi Again Everyone,
I had a chance to work on the WD-45 again last evening. Took off the carb bowl, disassembled it all, blew out everything I could find. I didn't find anything plugged, but I spent a lot of time making sure all the passages were cean and flowing air well.
When I put it all back together, I set both the idle mix screw and the main needle screw to 1-1/2 turns.
She fired up on the first spin, and settled down into a nice smooth idle. No missing, no loping, just nice and smooth. It throttles up nice and smooth when you crack it open - no missing or hesitation. Maybe just a hint of black smoke when you open the throttle wide open fast - just a hint.
Thanks for all the advice. I sure was afraid I had deeper problems than that!
Texas Denny
06-13-2007 06:58:01
 Re: WD-45 Not Running Well - Update in reply to Phill Snartland, 06-13-2007 06:43:32
Great, Phil. On one Farmall M that I used to own, I did that 3 times before I got it clean enough. You are clearly better at it than most! Its hard to know when the passages are clean enough!
