raodspeed for allis Chalmers b and c models
buzz68
06-12-2007 21:17:55
guy wanted to know the road speeds for the pre 50 alis chalmers tractors thanks bob
buzz68
06-13-2007 16:50:14
 Re: raodspeed thanks in reply to buzz68, 06-12-2007 21:17:55
That what I thought my john deer 1936 B has about that road speed might be a good choice for the wife to use on outing
any such thing like over dirve unit for these AC
have a behlen unit for my JD and dont want to leave her in the dust???
buzz
Bus Driver
06-13-2007 05:51:04
 Re: road speed for allis Chalmers b and c models in reply to buzz68, 06-12-2007 21:17:55
My post of 7 MPH was from memory. I have since looked at the link posted by Rod. Rod has done an extensive analysis of the speeds of his tractor. Nebraska tests of the B in 1938 with 7.00 x 24 rear tires resulted in 7 3/4 MPH. In 1950 with 10-24 rear tires, a B had an advertised speed of 7 1/2 MPH. In 1940, a C (distillate) with 9 x 24 rear tires tested at 7 1/2 MPH. A C (gasoline) in 1940 appears to have identical tires and speed to the distillate model.
Bus Driver
06-13-2007 04:13:55
 Re: raodspeed for allis Chalmers b and c models in reply to buzz68, 06-12-2007 21:17:55
Roughly 7 miles per hour.
Rod (NH)
06-13-2007 03:39:46
Hi buzz,
Ground speeds are dependent on engine rpm, various gear ratios and rear tire size. My analysis of ground speeds for my own B is here. All Bs should be the same provided they use the same rear tires and engine speeds. The Cs will be different since they had different gear ratios for the final drive.
third party image Rod
TxAllisMan
06-13-2007 13:56:57
 Re: raodspeed for allis Chalmers b and c models in reply to Rod (NH), 06-13-2007 03:39:46
its around 7 mph but may be faster if you have oversized tires
TxAllisMan
06-13-2007 13:56:48
