Need Help Identifying
LinemanFarmer
06-12-2007 17:42:15
Hello folks, I have found an Allis that I cannot find the serial # tag. I am new to looking at this make of tractor, and I looked everywhere and cannot find the tag. So I got the cast # off of the engine block: D220057 GA if that would help me identify I don't know. I know a little about the differnt models and I think it might be a WD???? I would appretiate it if you guys could give me some idea where to look for the serial # or just kinda identify it.
Thanks, Derek
Robert Mull
06-14-2007 10:53:34
 Re: Need Help Identifying in reply to LinemanFarmer, 06-12-2007 17:42:15
Here is a link to Bryan Smith serial number pictures , etc.
JMS/MN
06-13-2007 09:11:52
On a WD or WD45 the serial number is stamped on the rear vertical face of the differential, left side, below the left brake cover. WC, RC, WF, the number is in the center of the differential, on a flat spot near the top. B, C, CA, the number is stamped near the shift lever. Numbers will be preceeded by the letter designation of that model.
old
06-12-2007 18:39:43
Most Allis tractors don't have a tag as such. If its a WD it will be stamped into the rear end on the left side just under the brake cover. There will be a flat place where the numbers are. Also in the same place on the WC, and WD45 and all 3 look almost alike. Also could be an RC which again looks very close to the other 3 but with a smaller engine in it
