WD steering shaft bushing
tractormiallis
06-11-2007 19:57:11
Have a 53 WD. The steering shaft has worn through the bushing and into the steering wheel throttle support. Also, down by the steering shaft joint it is worn through and into the metal badly. I have a new support but it needs a bushing. Where can i get one? Also, it looks like a small punch is needed to get the joint apart below on the shaft. Anyone ever taken all that apart? It looks like quite a project to tear it apart and redo.
Texas Denny
06-13-2007 19:36:09
 Re: WD steering shaft bushing in reply to tractormiallis, 06-11-2007 19:57:11
You are correct about the punch. I've taken several of these shafts apart - it's necessary to pull the engine for rebuild. try to get a metal backup on the joint before using the punch. Usually they come out pretty easily if you don't peen the end trying to drive it out.
You could try your local AGCO dealer for the bushings. I have a lathe so I just make mine.
