C engine knock
catfish-65
06-11-2007 15:44:57
I have a c that has been taken out of mothballs and I am going to mow with. It ran fine for an hour and then it developed a knock in the motor. I dropped the oil pan and looked for something obvious. There was no chunks of anything in the pan, the only thing strange to me was, I could move the crankshaft forward and back about 1/8" is there a thrust bearing out, or an adjustment. Could this be my noise or is there something they are famous for? Please let me know, Thanks!
Dick L
06-11-2007 19:15:22
 Re: C engine knock in reply to catfish-65, 06-11-2007 15:44:57
Specs on your crankshafts end play would be .001 to .005. Pretty good bet the thrust bearing part of the main bearing is chewed up. Probly the crankshaft is wore to where new bearings will not take it up. The thrust bearing on that engine is one half of the front main bearing. A main bearing set gives you five inserts and the thrust bearing half that fits over the front main bearing cap.
catfish-65
06-12-2007 05:59:22
 Re: C engine knock in reply to Dick L , 06-11-2007 19:15:22
That is exactly the info I needed Dick, do you think I could get by with just installing the bearings without getting the crank polished or would that be stupid. Do you have a good source for bearings? Thank You for your help!
Dick L
06-12-2007 08:33:59
 Re: C engine knock in reply to catfish-65, 06-12-2007 05:59:22
There is no way any one could think what could be or should be done. The only way is with a mic. The crankshaft will need to be measured. Guessing that kind of stuff costs time and money. With that kind of end play in most cases the crankshaft would need to be ground and bearings matched to the grind. It is a good deal to have the shop that grinds the crankshaft to match the bearings. Using the word polish in crankshaft sets up the thought that it might be able to be done on a work bench. Not so. It needs to be done completely on a machine.
El Toro
06-11-2007 16:44:03
You may want to take a look at the bearings while the pan is off. Hal
TxAllisMan
06-13-2007 14:03:05
 Re: C engine knock in reply to El Toro, 06-11-2007 16:44:03
Endplay is determined by the thrust bearing and thrust contact on the crankshaft.
If your crank has excess thrust wear it can be fixed but it may be cheaper to find a good crank ready to install.
When you do put it back togther make sure to check the block for wear in the crank journal area wher the thrust bearing sets and make sure that the crank journals are shimmed correctly.
