CA transmission cover, shifter rail assembly
Les Brown
06-11-2007 09:22:47
Can my 52 CA transmission cover, shifter rail assembly be removed to replace the gasket without other dismantling? I am not a mechanic and thought I could replace the leaking gasket by simply removing the ten bolts holding the cover in place. To my disappointment, the shifter rails and forks are attached to the cover. Does this come out without other disassembly? Is there a simple way to replace the gasket.
Les Brown
06-11-2007 20:53:58
 Re: CA transmission cover, shifter rail assembly in reply to Les Brown, 06-11-2007 09:22:47
Thanks. I hoped it wouldn't be too much of a problem since the trans. works okay. Should the gear shift be in neutral when I remove the cover? Also, are there any tricks to lining up the forks that I should consider when replacing the cover?
Big Hunter
06-11-2007 13:19:22
yes, when you put it back together just make sure you line up the forks with the grooves that slid the gears
