A allis value
deene
06-10-2007 21:12:47
have found an a for sale runs well... older paint... needs repairs on one rim and a few other things...what is a ballpark for this machine?..also it has 16.9x28 tires on rear but the rims seem a little narrow for that size is this factory size?..what was the hp of these machines they are not in the nebraska test book..also will need new fronts and i think they are 18 in..best place for these?..thanks for all the replies
Coloken
06-11-2007 06:44:03
 Re: A allis value in reply to deene, 06-10-2007 21:12:47
Just found in my books that it was rated Neb at 44 belt and 33 drawbar. Kennyp
Coloken
06-11-2007 06:37:03
You guys are making me cry. A was my main tractor for years-went to the junk dealer. HP was somethng like 38 or so. Was a very low compression. It had a space above the pistons that was larger than the bore. That is the bore was way smaller than the block would take, I made inserts to drop in and raise the compression for a while. Then the only overhaul sleeve set I could find were for the "E60" power unit. These had full bore. I think 5 1/4 bore and 6 1/2 strike. I parked it when I had problem spinning the wheels inside the rims. No lug yo keep it from turning. They were 28 inch, but I don't remember the width.
David Maddux
06-11-2007 04:57:11
From what I have seen, you won't find one in any shape for under 6,000.00. I watched one restored sell for 25,000.00 last summer.
John (C-IL)
06-11-2007 04:34:25
Well, machines with the description you are giving have been offered for sale in the $6000 to $10,000 range. Some non runners that have required repairs have sold in the $3000-$5000 area. Some of the things influencing value is the presence of PTO, belt pulley and a starter. There has been reproduction sheetmetal available in the past and engine parts are available.
That is a rare tractor, surviving numbers are unknown but guesses are around 100 of the 1225 built from 1936 through 1942.
deene
06-11-2007 19:48:31
 Re: A allis value in reply to John (C-IL), 06-11-2007 04:34:25
thanks guys that is what i had suspected but wanted to ask am not sure about that 100 survivors as i know of about 4 others just in this area that are pulled at tractor pulls on a regular basis...have brought it home and am now looking for a float and gaskets for the big zenith carb but have been unsuccessful as of yet
John (C-IL)
06-12-2007 09:03:50
 Re: A allis value in reply to deene, 06-11-2007 19:48:31
I know what you mean about the 100 surviving tractor thing. When I got mine I found out that there were 4 in our club. Ernie Nutsch tried to put together a list of survivors and he said his best guess is around 100. I have talked to others that say there are fewer than 100.
We hauled ours out to the GOTO in Canadaigua NY and there were 7 of them there! Go figure!
David Maddux
06-12-2007 04:56:52
Check with Norm Meinert on those carb parts. He can come up with about everything for those old beasts. I don't have his no. but someone here will.
