WD45 Engine Overhaul Kit Questions
Vic Lovejoy
06-10-2007 07:18:24
I am preparing to overhaul my 1954 WD45 and while shopping for overhaul kits a question has come up... many of the kit descriptions indicate that that the sleeves are "overbore from 4" to 4-1/8"..."
So I'm wondering does that mean that the block has to be rebored from 4" to 4-1/8 before I can install the sleeves? I certainly don't want to get involved in something like that.
I have very bad oil out the exhaust problem so I figure liners and rings is going to be the best solution, plus as part of the restoration I figured rebuilding the engine and hydraulics would be best.
Any advice would be greatly appreciated.
vic
steve(ill)
06-10-2007 20:32:01
 Re: WD45 Engine Overhaul Kit Questions in reply to Vic Lovejoy, 06-10-2007 07:18:24
how much money you want to spend? i have honed old cylinders and put new rings in ad Denny said. lapped the valves and you can use umbrella boots if the stems have too much clearance.... either way, i would pull the sleeves and replace the o-rings seals. you can reused the old sleeves when honed, or like you seaid-- new kit. they slide right in, no boring.
Phil Munson NY
06-10-2007 10:56:03
Poor oil pressure on this tractor could be a number of things. The first of which I would check would be the OIL FILTER. These oil filters used to be a cotton sock which availed enough flow restriction to help build oil pressure. The newer pleated paper filters do not provide enough flow restriction, and as a consequence, poor oil pressure is the result. I understand that the correct oil filter can still be bought from Agco. As well, the oil consumption may well be the result of worn guides and umbrella seals on the intake valves. Unless you are using the tractor a lot of hours just installing new umbrella seals and the right filter may resolve your problems. best, Yeoman
El Toro
06-10-2007 09:12:41
If you are going to the expense of new sleeves and pistons you should have the crankshaft measured at your local auto machine shop. If the block is sludged up I would have it cleaned and new cam bearings installed. Close tolerances on the bearings determine good oil pressure. Your local auto machine shop can furnish new bearings
too. They would probably recommend at least to have the shaft polished. If its worn slightly worn they get undersize bearings too. Hal
Texas Denny
06-10-2007 07:49:21
The 4 1/8 cylinders fit the block without modification. They do boost horsepower, of course. I've found that about half the time the cylinders do not need replacement and rings are all that you need. If you have poor oil pressure, you may need work on the crank and the camshaft.
Your "oil out the exhaust" problem sounds like broken rings. I'd tear it down without running anymore and find the problem.
A couple of "if's" are required for valves to cause the problem you describe. "If" one or more of the intake guides are badly worn and "if" the drain holes in the head are plugged, oil could build up in the valve cover enough to flood a cylinder(s) with oil. More of a textbook failure than real.
