Pulling engine
jay snyder
06-09-2007 12:37:03
I have a WD45 that I want to build into a pulling tractor and I wanted to stroke it I was woundering what type of pistons to use if I wanted a 5 3/4" or 6" stroke and use a set of small block chevy rods. Don"t know if I should use 5.7" or 6" rods though I would like the pistons to be as large as possible. Also was woundering where to get sleeves for this and if they need to be welded in. Where do I get the crank stroked at? And anything else that you guys could tell about building a engine like this would be appricated.
El Toro
06-09-2007 14:41:09
 Re: Pulling engine in reply to jay snyder, 06-09-2007 12:37:03
You may be able to get sleeves from L.A. Sleeves
at 1-800-822-6005 or email them at [email protected].
There several places in my area that could probably do your engine. You could call them, I have the email address for one of them.
Rod's Machine shop is in Jarretsville, MD it may be too far away for you and his number is 410-692-
2857. The other machine shop is near Whiteford, MD and his number is 410-452-5255 and his email is [email protected]. His name is George Miller and he does a lot of JD engines for pulling. Hal
