WD Bush Hog Advice/Photo wanted
Snowfarmer
06-08-2007 15:47:28
I don't think the linkage is correct for the snap-coupler bush hog I have hooked up to my WD. The parts that hook up to the hydraulic arms are flat pieces of metal with no adjustments. At one end they have the pins that go into the sap couplers and at the other they fit around a one inch pin on the front of the bush hog. There are another pair of brackets behind the ones that the snap coupler bars and the drawbar hook into. This pair of brackes have several 5/8" holes running up and down them set about an inch apart. Am I missing some parts? If the bush hog was ever set down or had to be abandoned on an uneven ground one of the bars that hooks into the snap coupler would be either too long or too short. Does anyone have a photo of the proper set-up? The model is an old-style heavy-duty 305 s/n 507833
Tramway Guy
06-08-2007 17:24:59
 Re: WD Bush Hog Advice/Photo wanted in reply to Snowfarmer, 06-08-2007 15:47:28
If you have uneven ground, you hook up the shorter one first, then raise it slowly until you can hook the other one.
