Sparkplugs for my Allis B, what kind???
Pelle
06-07-2007 11:12:38
Wonder if anyone could help me out here.
My little Allis B 1939, needs new sparkplugs.
I wonder what kind i should use? In todays standards, e.g Bosh B6ES, or NGK...??? Well You see my problem. So help me get the right sparkplugs (the right number,"code" or what ever it is, the sparkplug-jungle is huge...)
Best Regards;
Per
Sweden
Gordon in IN
07-13-2007 20:27:12
 Re: Sparkplugs for my Allis B, what kind??? in reply to Pelle, 06-07-2007 11:12:38
Bosh Platinum.
Mark - IN.
06-08-2007 22:37:22
Plugs are getting scarce. I picked up a couple of sets of AC45"s, and clean my plugs. Got a bag off of the air compressor with...not sand, but similar medium, hit the air for 15 - 30 seconds per plug. Come out clean, so just blow off and check or regap. Also, had two of those old Black and Decker 12 volt plug cleaners that were sold in the late "70"s that did similar using glass beads. They sure were sharp...so sharp that came right off of the market shortly after going on. Four 1/4 turns at 15 seconds each until hit 360 degrees. I gave one to my brother whom still uses it off of a battery, I have the other that I changed the motor to 110 VAC and use when don"t feel like waiting for the compressor to fill up. Those things were great...a little too great apparently, and still are.
steve(ill)
06-07-2007 19:05:29
most guys use autolite 295
http://www.power-21.com/honeywellpower21i/PartDetail.aspx?b=A&pn=295
Rod (NH)
06-07-2007 15:56:44
Hi Pelle,
NGK B4 is a direct cross to the original AC45. I've been using the B4 for quite a few years now since I can no longer get the AC45. I've been very pleased with the NGK plugs.
third party image Rod
Dick L
06-07-2007 11:38:09
 Re: Spark plugs for my Allis B, what kind??? in reply to Pelle, 06-07-2007 11:12:38
They came from the factory with AC 45. This was a non resister plug. The AC 45R that you find around here in the US is a resister plug and not a good choice. I Googled a chart with the Bosh cross reference. The AC 45 is close to the top.
