7080 power director xx hi - lo range adjust on lev
jim ball
06-06-2007 14:36:45
i have 7080 with PD XX transmission. it shifts into hi / lo / park but with some difficulty.
i assume it is on cables from range/park shift lever. i have AC parts/ service / operator manual as well as ITT. find nothing. anyone have any experience with this.
glr62
06-06-2007 17:48:40
 Re: 7080 power director xx hi - lo range adjust on in reply to jim ball, 06-06-2007 14:36:45
Take the floorboard off and the side panel off. Watch how the shifter works. Lube everything up and add a spring to the lever that moves the cable from park to hi/lo. The spring from the panel that holds the cover in front of cab works great. Might need new cables also, but oil those bushings that the shifter pivots on, I usually just spray penetrating oil on them.
