Wishbone front on a C
Uh Oh
06-05-2007 20:40:53
im going to put a wishbone type wide front on my C, and im told it takes a B steering box and steering arm. is this correct? what else do i need to know? thanks!!!
Dick L
06-06-2007 07:50:51
 Re: Wishbone front on a C in reply to Uh Oh, 06-05-2007 20:40:53
I know several people that have put the B wishbone fronts on C"s and I guess they like it ok but I would think long and hard before doing it. I am a mix and match kind a guy and I have more mixes planned but that is one I wouldn"t do. Tracking four tire marks is the biggest problem I would have with it personally. I use all of mine in field dirt or in the yard. That might not be a problem for you.
Jerry Coulter
06-06-2007 05:38:50
Would you consider a wide front from a C or CA? Then you wouldn't have to change the steering box.
George Andreasen
06-06-2007 04:59:20
You were told correctly...the C steering box action would be reversed if you just turned the pitman over to fit the B axle. So if you turned the wheel right the tractor would steer left and visa versa. Might be a good anti-theft device!
Kip[UT]
06-05-2007 20:48:43
You will also need the front motor plate that locates the front pivot. For a cleaner installation you might want to use the radiator shroud off a B as well. Kip
