AM serial number?
Tony SChroeder
06-05-2007 20:32:56
I have found an old Allis Chalmers with an AM serial number. The number is stamped on the back axle of the tractor. AM-2787-13
Is this the model/serial number?
I have pics.
Kip[UT]
06-05-2007 20:54:39
 Re: AM serial number? in reply to Tony SChroeder, 06-05-2007 20:32:56
This is not a serial #. AM prefix is used to designate a casting number. You will find other AM numbers on different parts of the tractor.
Tony SChroeder
06-06-2007 05:25:28
 Re: AM serial number? in reply to Kip[UT], 06-05-2007 20:54:39
Where should I look for the serial number?
JMS/MN
06-06-2007 11:08:15
 Re: AM serial number? in reply to Tony SChroeder, 06-06-2007 05:25:28
That depends on the tractor model. B&C- the number is near the 3 spd transmission lever. Same for CA, but it's a 4 spd. WD, WD45, left rear vertical face of the differential, starting with WD. WC, WF, RC, center of the differential, near the top, starting with the model designation. Wartime WC will be at the top, ending in 'S', for the steel rear end, not cast iron. Still other models- post a picture of what you have. Serial numbers are always stamped, not cast into the metal. They are stamped during assembly on the production line., not cast in the foundry.
Tony Schroeder
06-06-2007 11:19:51
 Re: AM serial number? in reply to JMS/MN, 06-06-2007 11:08:15
I did some looking and found that it is a 'B'...it has a sickle mower on it also.
