Big A/C 4WD
Glenn F.
06-05-2007 09:35:10
Last night My dad, borther, son and I went to a nice local tractor show. They had an articulated A/C 4WD there with a V6 Cummins (I believe) there. I'm thinking it was A/C's first 4WD built largely with vendor parts, but can anyone give me the specifics: years built, horsepower, weight, transmission type, pto option or not, three point/hydraulics or not, etc.?
Interesting tractor....Would like to know more about it.
Thanks,
Glenn
Joe(TX)
06-06-2007 06:27:58
 Re: Big A/C 4WD in reply to Glenn F., 06-05-2007 09:35:10
The 440 Allis Chalmers had a 555 cu in Cummins V8 that gave it 165 drawbar hp. The unballested weight was 17,500 lb. It had a Fuller TA4510 10 speed 2 speed reverse and a Stieger drop box. No pto was available. Built 1972-76. It had a cat III 3 point.
John (C-IL)
06-06-2007 04:27:50
third party image
Here's your tractor.
Glenn F.
06-06-2007 05:02:08
 Re: Big A/C 4WD in reply to John (C-IL), 06-06-2007 04:27:50
Yep, that's it. Anyone have more details...weight, horsepower...?
Thanks,
Glenn
Dave from MN
06-06-2007 13:26:33
 Re: Big A/C 4WD in reply to Glenn F., 06-06-2007 05:02:08
Allis Chalmers 440 General information: Manufacturer: Allis Chalmers Model: 440 Years produced: 1973 - 1977 Total built: Factory: Original price: $38,179 Power: Engine: 218 hp [162.6 kW] Drawbar (rated): 165 hp [123.0 kW] Engine: Manufacturer: Cummins Fuel: diesel Aspiration: turbo Cylinders: 8 Bore/Stroke: Displacement: 555 ci ci [9.1 L] Compression: Rated RPMs: Torque: Firing order: Transmission: Type: Forward: 10 Reverse: 2 Mechanical: MFWD: standard Steering: Brakes: Cab: optional Capacity: Fuel: 3-Point Hitch: Rear Hitch Category: III,IV Rear lift: Power Take-off (PTO): Type: Rear speed (RPM): 1000 Tires: Ag front: 23.1-26 Ag rear: 23.1-26 Dimensions: Weight: 20,230 lbs [9176 kg] Wheelbase: Length: Width: Height: Ground clearance:
massey333
06-05-2007 14:57:37
Built under contract by Steiger 73-74.No pto,it was pretty much a dud
Dave from MN
06-05-2007 14:54:55
third party image
did it look like this one?
Glenn F.
06-05-2007 15:06:13
 Re: Big A/C 4WD in reply to Dave from MN, 06-05-2007 14:54:55
No....Older.
Glenn
JMS/MN
06-05-2007 14:06:47
Probably the 1974 440 tractor. Cummins V-8, 555cubic inches. Ten forward speeds. 3ph optional
