wd Allis tractor
Ron Rainbolt
06-04-2007 09:22:00
What causes a wd with magneto to backfire and die? After it dies it is very hard to start.
old
06-04-2007 10:01:27
 Re: wd Allis tractor in reply to Ron Rainbolt, 06-04-2007 09:22:00
Could be either mag problems of fuel problems. First thing I would check is if you have a good brite blue spark. Then pull the drain plug from the bottom of the carb and make sure you have a good steady flow of gas for at least 5 minutes. If either one isn't there then thats where your problem is
