WC serial numbers
Les Bales
06-03-2007 16:48:32
I bought a WC unstyled ans it doesnt have a tag. Where else is the serial number placed?
Harry J. Case
06-04-2007 20:59:30
 Re: WC serial numbers in reply to Les Bales, 06-03-2007 16:48:32
Hey Les On an early WC the serial number will be on the center of the pumpkin , also check the right hand side of the tranny for a casting date. thanks, Harry
old
06-03-2007 18:23:44
Never did have a tag on it. The number is stamped into the rear end houseing on the left side. You should see a flat spot and the numbers will be there. Should start with WC
bjb in Ne
06-03-2007 17:23:40
The serial number should be stamped directly onto the rear of the differential casting.
