New style plug wires?
Hossman
06-01-2007 17:54:38
Fellas,I installed a new set of plug wires today that had a differant style of terminal on them these were the cut to length kind but the crimp on terminals werent the kind im used to they didnt have the inverted point that you stick into the end of plug wire with sides that crimp onto insulation. These were little bushing type that you slide on the end and crimp tight but ther is no direct contact with core wire. Does the fire just jump threw the insulation into distributer?The direction on the back of box showed the old style with inverted point and not the ones that came in the box(typical)They seem to be workin ok but was wonderin if maybe I should cut back 1/4" of insulation and fold over core wire then crimp the terminals on, maybe someone out there has used these before and could give me a tip on what I did or didnt do right. Thanks Hoss
BCnT
06-02-2007 08:26:54
 Re: New style plug wires? in reply to Hossman, 06-01-2007 17:54:38
actually if you got a good ignition system the spark will jump the short gap and give you a hotter spark at the plug...i used to pull coil wire off distributor tower and hold it about 1/4'' away ...best thing for cleaning slightly fouled plugs.
anyhow,i've stripped and folded too...either way is fine.
460anger
06-01-2007 19:17:18
I us them all the time but I do like you said I strip it back fold the wire over and crimp the end on. always seems to work. I have not had any bad luck yet.
