WD-45 Not Running Well
Phill Snartland
06-01-2007 11:23:21
Hi Everyone,
I have a '54 WD-45 that I refurbished a couple years ago. Gradually, since the work, it's been running poorer and poorer. The problem is that when it's working hard (like plowing), it runs great. Strong and smooth. But when I do things that make it mostly idle (pulling shuttle wagons at shows, putting docks in at the lake, etc.), it seems to load up and miss, sometimes very badly.
Here are some clues. When it's missing, it sounds like one or more cylinders are just pumping air, not firing. One of the cylinders (#2) fouls plugs. The exhaust stack is very sooty - black at the outlet (rain cap is black - started out silver gray). I never have to choke it to start, unless it's in the dead of winter. When I rebuilt everything, I took the carb apart and soaked it overnight, blew it out and re-assembled with new parts from a kit (gaskets, float needle and seat, etc.). Float height looked pretty close to spec in the carb kit paperwork, so I didn't change it. As far as the adjusting screws, both the idele mix and the high speed needle seem to have no effect on running until they are very nearly bottomed out. Then the engine starts running even more ragged and will die if I keep screwing the adjustments in. When I screw either one out, they have no effect until the screw comes completely out of hte carb body, then there's a big vacuum leak and the engine dies.
Spark seems strong. I can wiggle the distributor shaft a bit (just enough to feel, but not see - maybe 0.015-0.020"). Points seem to last about a year before I need to replace them. I haven't adjusted the timing. I haven't touched that since I bought the tractor in 2002.
Any ideas? Some of the guys here at work suggested maybe the float is set too high. I'll try adjusting that and see what happens. Do I need to put new bushings in the distributor?
When I was plowing last fall, I found that I burned about a quart and a half of oil in 8 hours. Also, when I drained the oil this spring after the tractor sat all winter, a small but noticeable amount of antifreeze came out of the pan before the oil came out. Probably an O-ring at the bottom of a sleeve weeping?
Thanks for any ideas. I'll give anything a try.
JMS/MN
06-01-2007 14:33:43
 Re: WD-45 Not Running Well in reply to Phill Snartland, 06-01-2007 11:23:21
Any engine that burns that much oil needs a rebuild. Sounds like #2 is punching oil out, thus fouling the plug and stack. Check the float height with a machinist's gage- down to a 32nd of an inch. I boil out carbs in a sauce pan, plain water, til it boils- cleans out the gunk in passages. Needle settings are typically 1-2 turns out. Carb should be a Marvel-Schebler if it is original, TS464 series.
old
06-01-2007 12:07:07
From what you have said you have carb problems and its running way to rich. Sounds like its time to open up the carb again and clean it good. The main jet adjustemnt should effect it a lot more then what it is doing. The idea jet doesn't ever do much
