AC 5040 transmission trouble
randy stemple
05-31-2007 16:45:26
I have a 5040 with a 6 speed transmission. I have trouble with 4th gear hanging and not releasing. I have to take the top off of the tranny to place the rod in the N position. All gears look good and all the gears slide good when the top is off. Do I have a tranny problem or do I have a shifter problem? Any ideas for a fix?
Thanks,
Randy
Gatz
05-31-2007 19:36:42
 Re: AC 5040 transmission trouble in reply to randy stemple, 05-31-2007 16:45:26
I've got a 5040 with the same xmsn...and it hangs up a little in 4th also.
I found that if I push it to the left before trying to take it out of gear, it doesn't bind up.
It's not come out of the slots (yet!).
I was thinking about making a guide that would mount maybe 4" above the top plate...kinda like what an old JD shifter guide looks like.
Not exactly sure if the pattern would work out or not until I take some measurements.
Gatz
Bus Driver
05-31-2007 17:45:37
That is a UTB tractor, essentially identical to several models of Long (350,360,445,460). Look at the bottom side of the shifter cover. Does it have adjustments?
