Generator for B?
Hossman
05-29-2007 13:42:20
Fellas, Startin to go threw a lil' B i purchased last year and repair and or replace all the little mech. things that alot folks let "build up" over the years, anyhows the gen. seems to be bein used for little more than a belt tensioner, just a couple wires cut off here an there and i dont believe its doin much in the way of chargin the batt. Is there a way I can check this out with my multi-meter at the batt. with engine off and then across terminals with engine runnin? Or maybe at the gen. itself? and one last question, if the dang thing aint workin could i put a gen. from a WD on the B? I have a gooden from a conversion my Pa did on one of his tractors. By the way there is no threeway switch and the headlights aint hooked up. Thanks for any help, Hoss
souNdguy
05-31-2007 07:10:38
 Re: Generator for B? in reply to Hossman, 05-29-2007 13:42:20
Do a motor test on the genny.. Slip belt off, and jump bat power to the armature.. and then ground field ( should be A-circuit ).
if it spins (motors ).. it should charge. .. if it charges.. it should spin.. etc.
Gennies are pretty bullit proof.. as long as the brushes are good and the mica isn't proud... and it hasn't been abused in overlaod situations too long.. etc.. if it needs opening.. lube the bushing/bearing.. whatever it has.. ress the commie if it needs it.. inspect brushes and mica..
Soundguy
Hossman
05-30-2007 16:11:44
Fellas, Thanks for the responses,I have a three way switch (original) and an ampguage also I bought a whole elect. box off a feller and the amp gauge on the tractor might be good it aint workin but might not be hooked up aint got that far yet.I usally try to keep em fairly close to original if I can. Thanks again, Hoss
Kip[UT]
05-29-2007 21:28:38
I have an excellent original 3-position switch.$50 & I pay shipping. 208-731-3324 Kip
