HD5B hydraulic blade control valve.
jojohn
05-26-2007 21:46:27
Hello,
Can anyone help in locating a breakdown of, or a replacement of, a control valve for my 1951 HD5B.
The only identification on it is, A.W. Cash Co.,
Decatur, IL and the number 21716. It is powered up and down and has a position to float the blade. It mounts with four bolts to the hydraulic fluid reservoir in a square pattern with 4 1/2" between the bolt holes. Any help would be appreciated. I can't have the ONLY one ever made, but it is certainly turning out to be that way. I can't find reference to this anywhere. My dozer has effectively become a large doorstop as I can't raise the blade. I checked the pump and its good. The pressure relief is keeping the pressure from building enough pressure to raise the blade. When I open the valve to the raise position, the fluid in the resovoir swirls fast. I think that the guy that I had do some work on it left a piece out, but can't prove it. Help . . . .
