1940 B hyd. , what wt. oil do I use ?
fdbyrd
05-26-2007 12:58:58
I just removed the hyd. sys. from a 49 C & installed it on my 40 B. The C had what looked 30 wt. in it, the B had what looked like 140 wt. What wt. should I use with the hyd. sys. Also, I will be using a cyl. from a CA. Thanks, Norman.
mjourdan
05-28-2007 04:46:26
 Re: 1940 B hyd. , what wt. oil do I use ? in reply to fdbyrd, 05-26-2007 12:58:58
I've always used 20 weight non-detergent motor oil in my B, which is what the manual calls for. I just changed mine this weekend but instead I went with a universal transmission/hydraulic oil, I've read of lots of people using this type and I got tired of buying expensive quarts of hard to find 20 weight non-D. at hardware stores.
El Toro
05-26-2007 16:44:36
I would either use Hytran or Hygard from JD. Hal
wgm
05-26-2007 15:29:19
This tractor uses the same oil for both the transmission and hydraulic system. I use hytran in my B. Been using it for years.
Eddie Jones
05-26-2007 13:05:38
I use 20W in my 1939 B.
