Identification
Ernest J. Petro
05-25-2007 17:37:09
I have just purchased a D-12 series III Allis Chalmers farm tractor which contains many numbers. I believe the number pertaining to this tractor is AM5511-4 but then I don"t really know. When ordering parts what number should I use to Identify the tractor itself? How can I tell what the HP is as well as the year?
Ronnie Collier
05-28-2007 14:55:50
 Re: Identification in reply to Ernest J. Petrocelli, 05-25-2007 17:37:09
My torque tube states I-400 I629 and the motor side is 12-7737-R, on right side I found tag under dist. on block looks like DG24T and casting # AM 5511-4, it left the factory as a loader/back hoe, 4cyl. gas, I need info for head gasket. thanks Ronnie.
steve(ill)
05-26-2007 07:11:54
there are 4 bolts holding the motor to the BELL HOUSING. it is called a bell due to its shape. it is actually the clutch housing that covers the engine clutch. it is the front part of the TORQUE TUBE, the tube bolts to the transmission at the back and the motor at the front. the drive shat from the clutch to the transmission is enclosed inside the torque tube.
John (C-IL)
05-25-2007 18:24:04
third party image
THe number you gave is a casting number. Check where the white tape indicates in the picture for the serial number. It will begin D12-?????.
Erne Petrocelli
05-26-2007 06:51:11
 Re: Identification in reply to John (C-IL), 05-25-2007 18:24:04
Man you guys are good! Had it not been for your response I would have never found that number! The idea of marking with the tape is a fantastic idea. Thanks for that too! I know very little of tractors and less of the proper names of the different parts of a tractor. Just what is the name of the part you told me to look for that number? Well thanks too you I found it and here it is,I think. There isn't a alpha prefix, 12-6018-R
How would I find or order a parts manual for the tractor when I don't know what I have? Can you help me on that?
Thanks to the "Bull" Mr.El Toro and thats no bull.
ernie Petrocelli
05-26-2007 08:39:58
 Re: Identification in reply to Erne Petrocelli, 05-26-2007 06:51:11
No prefix just 12-6018-R
Ernie Petrocelli
05-26-2007 14:50:59
 Re: Identification in reply to ernie Petrocelli, 05-26-2007 08:39:58
12-6018-R
Ernei Petrocelli
05-26-2007 08:34:39
Did you get my last message?
El Toro
05-25-2007 17:55:34
That may be the serial number and was made in 1963. The engine had 139 cid and was rated at 31hp. Hal
23hp rated on drawbar, 29hp max on drawbar, pto hp max at 33.3, pto rated hp 28.5
Ernei Petrocelli
05-26-2007 08:32:13
 Re: Identification in reply to El Toro, 05-25-2007 17:55:34
