WD-45 Hand Clutch Kick-out
Phill Snartland
05-24-2007 10:38:04
Hi All,
I've been plowing with my WD-45 and a 3-14 snap-coupler plow (flies in 3rd gear!), but I don't have the hand clutch kick-out on my tractor. I'm a bit worried about catching a rock (the plow is a model 53 - rigid, no trip bottoms). Does anyone have one they'd sell, or could you sketch one up and take photos - I can probably fabricate one if I can see one and have some dimensions.
Thanks for your help!
BushogPapa
05-26-2007 19:30:38
 Re: WD-45 Hand Clutch Kick-out in reply to Phill Snartland, 05-24-2007 10:38:04
If it has a "Traction Booster", it outta have the linkage to kick the clutch out, too..!!
That large spring that the PTO shaft goes through is the heart of it all..remove shims to make it kick out under more load..(or help to keep the front down)..!! 3rd is not good..it is too fast..! Get a 4 bottom and run in 2nd..!! The AC mounted plows had shear bolts...you will need a few as spares..!! Always check to see that the lift-arm latches will release, if the drawbar unlatches... The hand clutch should trip, even with a "pull-type" plow..when you hit a rock.. When she gets to pulling really hard, you will have to hold back on the hand clutch, to help keep the front end down...!!
Ron..
Texas Denny
05-25-2007 07:04:58
See the posts called "plow attach" below. Doesn't your plow have hook like the one shown? If it does, it is the safety device and you don't need the kick out. I don't think I ever saw a two or three bottom plow without the spring release.
Phill Snartland
05-25-2007 07:29:42
 Re: WD-45 Hand Clutch Kick-out in reply to Texas Denny, 05-25-2007 07:04:58
Hi Denny,
My plow connects into the snap coupler hook with a ring on the tongue of the plow. I've not seen a spring releasr arrangement like you're talking about. I couldn't find the posts you mentioned either. The manual pages for the Model 73 plow you sent me doesn't show anything like that either.
The plowshares on my plow are bolted rigidly to the frame, so no trip in that area either.
Thanks for any suggestions.
Phill
Texas Denny
05-25-2007 09:45:41
 Re: WD-45 Hand Clutch Kick-out in reply to Phill Snartland, 05-25-2007 07:29:42
Yep. Your right. I was talking about the pull type plows. For snap coupler plows, the kick out device is the only choice.
JMS/MN
05-24-2007 21:54:35
I have several WD's and a WD45- thought at least one of them had that option. Also checked the 'nummy' shelf in the shop, thinking I had removed one. Found none! I still remember removing one, sometime in the past..... Just remembered I have another 'parts' WD on a trailer- will check that tomorrow. We live about a half hour apart- if I find what you need, I'll call you.
Sid
05-24-2007 19:06:10
"I'm a bit worried about catching a rock" Might be a good idea to drop down a gear. I may not know much bout plowing but my experience is that third gear is way to fast to do a decent job in the first place. As fast a third gear is you still gonna get bumped pretty good even with a clutch throw out. Just may opinion which may or may not be so but until I see different I am going to stick with it.
