Hydraulic cylinder sealing on a B
Gene Cockrell
05-24-2007 08:32:59
Howdy all, I have a little problem with a leaking ram cylinder on an early B.
I have two leaks, one is from the gland nut end and I have already found the nice post on repacking a B hydraulic cylinder.
The problem I am having is that there"s a second leak where the cylinder screws into the hose attach fitting. I have everything apart but was unable to see any sort of seal, o-ring, packing, pipe thread dope, etc. there. How is this supposed to be sealed?
thx in advance
old
05-24-2007 13:55:37
 Re: Hydraulic cylinder sealing on a B in reply to Gene Cockrell, 05-24-2007 08:32:59
Well if your talking about the hose and it screwing in thats pipe tread which has a tapper and thats how it seals. The tight you make it the better the seal
Rod (NH)
05-24-2007 10:02:49
Hi Gene,
I didn't take that end of my cylinder apart but I suspect it is the same as the gland end in sealing. If that's true, it's simply a metal-to-metal seat between the cylinder end itself and that end fitting. The sealing surfaces have to be true, burr-free, squeaky clean and the joint tightened fairly heavily for the seal to function well. If you have a continuing problem with leakage there, I'd consider using red Loc-Tite on the straight threads. You'd then have to use heat if you ever wanted to take that joint apart again. But that shouldn't be often (probably never). And it would stop any leakage. Or you could just try using any common thread sealant.
third party image Rod
