AC C
luther
05-24-2007 04:11:56
Looking for info on how big of a bore I can put into my C . And where can I get the parts.
luther
05-24-2007 06:03:20
 Re: AC C in reply to luther, 05-24-2007 04:11:56
I think I will save a lot if I just go with the 3 7/16 . And put a little work on the Head. Thank You Dick
Dick L
05-24-2007 08:01:44
 Re: AC C in reply to luther, 05-24-2007 06:03:20
I have taken as much as .200 of the head and domed the pistons. .100 off the head will change the exhaust sound. You can also use small block Chevy valves in the head. You do have to grind down the diameter to get them to fit.
Dick L
05-24-2007 04:37:44
3 7/16 unless you want to spend big bucks and bore the block. If boring the block for over 3 1/2 you have thinned the bottom bore to where you will be very weak between the pistons. It takes money and someone with some deep thought about details
