G questions
riverbend
05-22-2007 19:28:39
I have been having a heck of a time finding a good block for my Farmall Super C, and I am needing to get some cultivating done. My neighbor has a Allis Chalmers G with cultivators. It looks complete, has been shedded, but has not run for a few years.
Questions:
1) Do these tractor have any well known quirks that I should know about before trying to start it ?
2) Are the operator's manuals still available ?
3) Can they be easily set up for two rows ? 4)I'm on 32" rows and the rear wheels are at about 58". Can I move the rims to the outside of the wheels to increase the width ?
5) Any advice for resetting the tie rods with a wider setting for the front tires ?
Thanks
Greg
Dick L
05-24-2007 08:54:13
 On The Two Row in reply to riverbend, 05-22-2007 19:28:39
You would have to build something to make it a two row. I have seen pictures where they had two row and real narrow 4 row cultivators on a G.
I have only cultivated pumpkins with mine and ofcourse one row. You will love cultivating with the G.
Joe M(GA)
05-22-2007 19:55:53
 Re: G questions in reply to riverbend, 05-22-2007 19:28:39
Check your fluids both engine and tranny, G's have a low humor for being low on either oils or antifreeze, be sure you have oil pressure, they are prone to loosing prime on the oil pump.
Manuals are avail thru this site, EBAY, or Jen-sales.
see if these pictures help with the rest-
third party image
third party image
riverbend
05-23-2007 19:56:50
 electrical questions now in reply to Joe M(GA), 05-22-2007 19:55:53
Joe M,
Thanks for the information on how to set the whels wider. It looks like 64" is one of the standard settings.
I went over to the neighbor's today and we dug the little tractor out of the shed. Tires were low, but holding air. Rears look new. Fronts are mismatched - 1) 4.00-12 wheelbarrow tire, 1) 4.50 - 12 square profile Carlisle. Trans was low n oil. I used 80W90 to refill. Engine oil was dirty, but full. Spinning the engine with the starter showed 75% on the oil pressure gauge.
The battery (6V) was dead and hooked up with a negative ground. There is a sticker on the right fender (?) that shows a schematic with a positive ground. When they last used the tractor, it was as found. Does that sound right ? Tractor serial number is G8490, if that matters.
There are two switches by the ammeter. One is a toggle switch and the other is a pull type. They pull switch has two positions, so I'm guessing that it is the light switch, leaving the toggle as the ignition. Is that correct ?
Thanks again
Greg
Joe M(GA)
05-24-2007 19:00:23
 Re: electrical questions now in reply to riverbend, 05-23-2007 19:56:50
I always hate to guess how others have played with wiring- when new it was a positive ground, the push pull was the off on, and the pull out three position was the charging/ light switch. If it were mine, I"s pop the hood of and just take a quivk look at what is what.
Here is how it was when built
third party image
