WD Final Drive Lube Points
Chad B. Allis
05-21-2007 14:28:23
I can't for the life of me find the final drive lubrication/fill points on my WD. Feel like a dope as I think I should be able to see them. Can someone help me?
Thanks!
wdTom
05-21-2007 17:59:42
 Re: WD Final Drive Lube Points in reply to Chad B. Allis, 05-21-2007 14:28:23
It is more work, but you are better off removing the pans to clean them out. They can be pretty muddy if the oil is 40 years old.
Brian G. NY
05-21-2007 16:20:33
All the WDs and WD-45s I've seen have fill plugs located in the upper part of each of the pans. Its "drain" plugs they ain't got!
Gatz
05-21-2007 15:01:23
There aren't any.
Re-lubing will require removal of the pan.
Think it only takes 1 1/4 to 1 1/2 quarts of SAE EP80 gear lube per side.
You'll need new gaskets, or you can make your own from cork material.
