Hi- I am a new owner of a 1957 WD-45, with a loader, a log lifter and a recently rebuilt engine. It has been converted to 12V.The loader has a separate hydraulic pump for the loader, which is the tubing frame/dump bucket kind mentioned elsewhere; I believe it's the original A-C. (I have done most of my own mechanic work for the past 30 years; I have a pretty extensive set of tools, jacks, etc. They're at home; I can bring them as needed to our woodsy 80-acre land about 100 mi. away.) I have several urgent questions. When I bought it, it ran fine. When using it to unload a A-C disc I bought for it, I was having some trouble finding the gears. It actually seemed like R was between 1 and 3 for a couple tries. Suddenly, the gear shifter no longer seemed connected to anything. It just flops around. The cover for the gear box looks like somebody had it open in the past couple years, and sealed the gasket with blue automotive sealer. what has happened? What is is going to take to fix it? The front hydraulics work well, if somewhat touchy. However, when I move the hydraulic lever on the steering column, nothing happens. On the back of the tractor, a hydraulic line comes back and is capped off by a small pipe cap. On another WD-45, there seems to be some sort of snap-coupler. I recently purchased a A-C disc that has been used for years with a WD-45. It has four gangs in two rows; the front two gangs have a spring between them, and the angle between them and the rear gang is controlled by a hydraulic cylinder. What will I need to get that working? So, those are my questions- 1) What broke in the shifter and how do I fix it? 2) Is my rear hydraulic system broken? How do I fix it.
